Sep 22, 2016 9:14 AM UTC
Toolkit Asynchronous Application Configuration
I am getting below mentioned error when trying  to create Toolkit Asynchronous example.
error LNK2019: unresolved external symbol_ProEngineerStart referenced in function_main()
I have used example file provided in toolkit installation folder → simple_async.
Anyone can help to configure t for Toolkit Asynchronous application
Sep 28, 2016 7:36 AM UTC
The Problem is Solved,
I missed pt_asynchronous.lib in the Linker
Sep 22, 2016 9:29 AM UTC
Are you using their 'make_simple_async' makefile?
What tool are you using for the compilation and for which Creo version?
Sep 22, 2016 9:38 AM UTC
Yes Tomas,
I am using make_simple_async
Creo Version 2.0
Visual Studio V2010
Sep 22, 2016 9:47 AM UTC
Ok, that's correct. Could you please post the whole output of the compilation? Have you made any change in the makefile?
