Nov 23, 2012 8:28 PM UTC
TR: Best use of SSD hard disk for ProE and Mechanica
De : G. Bon [
    Nov 26, 2012 8:30 AM UTC
    Hiya GB
    If your machine has enough memory, you should not see that much difference
    with ProE performance on a ssd or standard sata.
    I just run OCUS benchmark on a Win 7 64 bit system with 4 gb, then the
    same tests with 12 GB and standard sata, then the same tests with the 12GB
    and SSD and there is very little difference in the 12 gb results, the ssd
    actually looked slower on some results, but that could just be where the
    wind was blowing : -)
    So put your working files where its easy for you to administer. We keep
    all user info, cache etc in a "Users" folder under the ptc install folder.
    the Creo Agent always puts stuff in App Data\Roaming and Local as well
    Don't know if there are any performance increases with Mechanica, will get
    one of my guys to test this and see if we get any speed increase splitting
    the results to data
    Best Regards
    Chris Collinson
    CAD Administrator
    Nov 26, 2012 9:31 AM UTC
    I now run Mechanica on a RAM disk (24 GB machine; Pro/M WF4 can only use 8 GB). There are definitely speed increases both from putting the temporary files on a fast 'disk', and from putting the results there. For large analyses, the results are written non-sequentially across maybe 12 files so you could see a big improvement from writing them to an SSD.
    I don't know what the cost is likely to be in terms of 'using up' disk write cycles... but the best thing is probably for you to experiment using your typical analyses, looking at all three combinations of temp files, results, and both on the SSD.
    Let us know what you find!
    Jonathan
    Nov 26, 2012 5:02 PM UTC
    Below are some results of my informal SSD testing in my HP 8740W laptop.
    Test
    Disc drive
    SSD
    Launch Pro/E (WF5)
    165
    6
    Start up windows 7
    121
    34
    Launch Solidworks 2010
    180
    12
    Launch outlook
    97
    8
    OCUS overall
    2568
    2484
    OCUS CPU
    1493
    1445
    OCUS Graphics
    1074
    1039
    OCUS HD test
    233
    92
    Reading from SSD has a huge improvement, write is about a wash or can be slower in some cases. If you data is on your SSD when you load it, it will be quicker, saves will be a wash.
    Make sure you have the SSD firmware up to date and any windows/bios settings set properly. I have a crucial drive that needed power to the drive during sleep mode so it can do maintenance. I didn't have this set so my drive filled with "garbage". In the sleep mode, it will go through and clean the garbage (this keeps the drive from witting to the same spot over and over from my understanding). My drive filled with garbage and would not boot. I had to reformat and update firmware to bring it back to life. Just a PSA.
    I love the speed overall.
    Jim
