6-Contributor
Traceback error when exporting as .pvz
I have a problem about exporting my model into .pvz file. However when i attempt to export, they got an error that generates traceback.log file.
You can see some attempts that i tried;
- Updating graphic card driver
- Assigning a parameter which enable_opengl_fbo no
Emeritus
Hi @himungan,
Our Support Assistant should not have suggested to publish your question related to Traceback on the Community. It is likely to be a technical glitch that we need to fix on our end. We will open a case for you.
I hope that this experience will not discourage you from future participation in the Community.
himungan6-ContributorAuthor
6-Contributor
Did you open the case? It is critical issue for us.
Thank you
StephenW
Community moderators don't open tech support cases.
You need go to https://www.ptc.com/en/support and create a tech support case
OR
If you are thru a VAR, you will need to contact them for tech support.
How are you trying to export a model to a .pvz file? Those files are ProductViewZipped files and usually generated by Creo View Adaptors now.
6-Contributor
File --> Save As -- > Save a copy --> Creo View (.pvz)
