Trobles with Creo Anays after upgrading of Windows
I have had running Windows 10 and Creo 11.0.3.0.
After I have upgrading Windows to 11, Ansys in Creo will not start. Creo stops with a fatal error.
If I start Creo as an administrator, if runs with out problems.
Does any of you know the problem, and that is it I shall have rights to?
Allan
akokAnswer
Afterwards have there been coming a Windows update. It have solved the problem.
maybe traditional trick will help ... uninstall/install Creo.
akok12-AmethystAuthor
Thank you, but have tried.
It works if I have a PC with Windows 11 installed from clean.
akok12-AmethystAuthorAnswer
