Apr 11, 2015 4:40 AM UTC
Trouble converting .prt file into .stl format...
Hello everyone, I am working on a solid model here and i want a 3D print of it and the printer requires .stl file format, the problem is my solid model which is a .prt file is not saving as .stl file format. there is no option available in 'save as' drop down menu where i can select the file to be saved as .stl file format. My .prt file is a complete solid not a surface. Anyone here knows where is the problem? i have attached the file i want to convert
I am using CREO Parametric 1.0.
simranAnswer
Apr 11, 2015 12:21 PM UTC
Hey thanks for help I have resolved the issue. Actually I had to scroll down to see other file formats saving options.. my bad sorry for bothering you guys...
thanks for the help though..
2-Explorer
Apr 11, 2015 4:56 AM UTC
See the expected steps in http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/data_exchange/To_Export_to_an_STL_Render_OptegraVi…
Also there may be a bug in Creo that stl is only available in assemblies. Re: .stl file creation with PTC Creo Student Version
I know it worked on parts in WF5, so I don't know why it would not work in Creo, but there it is. Documentation says it works, users say it doesn't.
Apr 11, 2015 7:41 AM UTC
Creo 1.0 has its share of problems. This could be one of them.
I've attached an STL file with reasonable resolution for printing.
I made this with Creo 3.0. The save-as option for stereo lithography is there by default.
simran1-VisitorAuthorAnswer
