May 29, 2014 10:01 AM UTC
Two views assembly configurations on one drawing
Good morning,
I have one assembly and I'd like to show it in two configurations, one with a part constrained to a 45º and another with the same part at a 90º angle.
I have tried to do this with Simple Reps but to no avail.
I first tried to give the angle constaint a different value in each representation but it changed throughout all SRs.
I then tried to have two angle constraints, enabling and disabling per SR but again the enabling and disabling changed throughout all SRs.
Any advice gratefully received.
jsarkarAnswer
May 29, 2014 10:52 AM UTC
You should use snapshot instead of simplified representation. Lets make the angle 45 deg, then u open drag components and click on save snapshot. right click on snapshot and make toggle for drawing. similarly do for other configurations.
Now in the drawing, place view and properties box u check for exploded views and selecte the snapshots.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS30049&posno=2&q=snapshot in drawing&nav=ptcproductgroups||||Product+Group||&source=Search
jsarkar1-VisitorAnswer
ASC1-VisitorAuthor
May 29, 2014 11:00 AM UTC
Thank you, Jayanta. I'll have a play around and let you know how I get on.
May 29, 2014 11:22 AM UTC
Dear ASC,
welcome to the forum.
Jayanta Sarkar
May 29, 2014 1:28 PM UTC
HUGE DISCLAIMER: As with most things with Pro/E there are numerous ways to accomplish a task, The optimal choice may depend on many factors regarding what output you need and how it will be tracked.
If you just need to see the component at those 2 places, I would stay away from both mechanism and snapshot. Mechanism is one of those tools that has great power but in my opinion is overhead when you just need to see a component(s) at discrete positions. Snapshot will not update the view automatically when design changes happen and to update you will have to put the assembly back in that configuration to update the views that use those configurations.
I know family tables have a horrible reputation but this is the type of example when it may be the most appropriate course.
The way to do this with a simplified rep would be to use a technique called "overloading". Using this technique the same component is assembled at each position you need to see it in, then use simp rep to see only one at a time.
Dale_Rosema
May 29, 2014 1:59 PM UTC
Or you can add angle dimension to the family table and have the two separate instances. I do that frequently with things that are closed (0 degrees) and open (90 degrees).
ASC1-VisitorAuthor
May 29, 2014 2:01 PM UTC
Would this cause 2 BoM items to be created (i.e. Part1_Open and Part1_Closed)? Our requirement here is to maintain a single BoM reference.
