Jun 22, 2010 3:39 PM UTC
Unable to open 64bit skeleton in 32bit
Has anyone come across the issue that a file being done in 64 bit ProE can't be open in 32 bit ProE. If so what is the fix? I have not check PTC website yet, I figured I would put it out here first.
WF 3.0 M130
Intralink 3.4 M050
TIA
Michael Wimberly
Engineering Applications Support Specialist III
Security & Survivability
BAE Systems Land & Armaments
9113 Le Saint Drive
Fairfield, Ohio 45014 U.S.A.
(513) 881-4843 Direct
(513) 833-3565 Mobile
(513) 881-5087 Fax
-<">mailto:->
P Before printing, think about the environment.
mwimberly1-VisitorAuthor
Jun 22, 2010 4:09 PM UTC
Is this the way of saying "I can't tell you what the solution is". This is what I get from PTC's website when I select on SPR's that talk about the same issue.
PTC recommends using this tool to help diagnose issues being encountered while running PTC software or as a part in determining what value there is in updating to a particular Release or MOR.
Please note that SPR descriptions frequently do not detail enough information to determine a match with your software behavior. Simply stated, different SPRs can have similar symptoms. Conversely, an SPRs can exhibit multiple symptoms that may or may not be captured in the description.
SPR information is offered for your limited review and within context. PTC Technical Support recommends weighing the above factors when reviewing the SPR information. In all cases where it applies, refer to the TAN associated with the SPR and contact Technical Support if you need further information.
Michael Wimberly
9113 Le Saint Drive
(513) 881-5087 Fax
-<">mailto:->
Jun 22, 2010 8:42 PM UTC
Upgrade to WF3.0 M190 or above in both systems. I had this issue and the
upgrade fixed it.
Att.
Mário L. Secco
www.3dsecco.com.br - blog.3dsecco.com.br
Em 22/06/2010 12:39, Wimberly, Michael D (US SSA) escreveu:
> WF 3.0 M130
> Intralink 3.4 M050
> TIA
> Michael Wimberly
> 9113 Le Saint Drive
> (513) 881-5087 Fax
> - <">mailto:->
