Unable to Save as a Mirror Assembly. Creo Shows Fatal Error
I am using Creo Parametric Release 5.0 and Datecode5.0.6.0
Creo shows Fatal Error while save any assembly as mirror assembly. Issue happening with 2 users. Please solve ASAP
    You need to send your log to technical support - "Open a Support Case": https://www.ptc.com/en/support/case-logger
    Creo 5 is out of date and no longer supported. Update to a newer version of Creo.
