unable to view network drives when trying to open or set working directory in creo3 using windows 10
This works fine in windows 7, but within windows 10, I am trying to open a creo3 file on a network drive or trying to set working directory to a network drive, it does not see those drives.  Yes, already have mapped those drives.
Any idea why this is not working on the windows 10 seats?
I asked Google ... Windows 10 We can't verify who created this file. Are you sure you want to run this file? and receive list of links. One of them is:
https://www.technipages.com/fix-we-cant-verify-who-created-this-file-error
Q: Can you see network drives from Paint, Word or another application ?
Q: If you open command prompt and enter cd /D X: command, what happens ? (X: is your mapped drive)
Q: What operation system is running on server ? Windows ? Linux ?
Please attach some pictures of your environment.
Martin,
Q: Can you see network drives from Paint, Word or another application ?  YES
Q: If you open command prompt and enter cd /D X: command, what happens ? (X: is your mapped drive)  WORKS CORRECTLY, CHANGES DIR TO DESIRED DRIVE.
Q: What operation system is running on server ? Windows ? Linux ?  WINDOWS 10
Explain in detail what pictures you want to see.
Q: How do you launch Creo ? Try also double-clicking parametric.exe from Parametric\bin sub-directory.
Pic1: File > Open dialog box
Pic2: Set Working directory dialog box
Pic3: Open system window from Creo (i.e. Dos prompt) and enter cd /D X: command, also enter set USERNAME command
