Update purge.bat file for 64bit OS
It is necessary update purge.bat file for all 64bit operating systems.
Sometimes system doesn't recognise 64bit platform and then do you have to manually repair the purge bat file - see the discusion: Can't able to purge
yes it's  crucial
Do you think, that is good for customer if they install software and then they have to change some internal / standard *.bat files?
Somebody it is only CAD user and they need to use software - no configure / programing any internal *.bat file
Imagine: do you have to instal 10 Creo workstations - and 5 of them not working correctly. It is only about correct settings in *.bat files and everything is possible if you have correct instalation medium.
I am customer - I would like to have the correct default settings / the corerrect instaltion files
I haven't had to repair the batch file yet but the manual entry of the environment variable is really outdated in the modern age.  I have had to move a couple of DLL's to the windows folders in the past and ever since, the purge has worked without edits.
Here you can find temporary solution:
DomenicLaritz
Then please vote up and not down!
