Mar 30, 2015 6:43 PM UTC
Upgrade from WF5 to Creo 2.0 token not updated correctly
Recently upgraded from WF5/Creo Elements to Creo 2.0. Existing prt, asm & drw file tokens changed from WF type to generic Windows token when viewing in Windows Explorer. Does anyone know how to update them to Creo tokens?
Thanks, Tom
dnordinAnswer
Mar 30, 2015 8:10 PM UTC
Tom,
I believe you're talking about the Windows file association.
Look for the registry file "<loadpoint>\Creo 2.0\Parametric\bin\pim\xml\created.reg", and install it (as admin). It should have the file associations in it.
<loadpoint> is where you installed Creo Parametric.
Dan Nordin
BAE Systems
dnordin16-PearlAnswer
Tom,
Dan Nordin
BAE Systems
tcarullo1-VisitorAuthor
Mar 30, 2015 8:39 PM UTC
Dan,
Thanks, yes, I was refering to the WIndows file association. I ran "created.reg" and it worked to a point. Files with *.1, *.2, & *.4 to *.22 did not update, but *.3 & *.23 on up did. Pretty wierd. By the way, I switched over to Creo 2.0 on 01/01/15.
Thanks again, Tom
Mar 30, 2015 8:48 PM UTC
Dan,
Tried something that worked. I went to the Windows start button and clicked on "Default Programs", then "Associate a file type or protocol with a program". I highlighted the *.1 extension, changed the program to another program, then went back and changed it to Creo 2.0 and everything cleared up.
Thanks again for your help. Tom
