Use creo applications for multiple sessions in Windows Server at the same time
I want to install creo parameter application on windows server. Can I use this application simultaneously in a multi-session scenario? If possible, what should I do? How to apply for a license?
Translated text from Simplified chinese to english using google translate.
Body- 我想在 Windows 服务器上安装 creo 参数应用程序。我可以在多会话场景中同时使用此应用程序吗?如果可能,我该怎么办?如何申请牌照?
- By Community Moderation Team.
VladimirNAnswer
Look here—— "Set Up Licenses": https://www.ptc.com/en/success-paths/get-started-creo-parametric/setup/set-up-licenses
Translated by the Community Moderation using Google Translate
看这里—— "Set Up Licenses": https://www.ptc.com/en/success-paths/get-started-creo-parametric/setup/set-up-licenses
Take a look:
thank you for your reply. How to obtain a floating license?
感谢您的回复。请问如何获得浮动许可证?
VladimirN24-Ruby IVAnswer
