Jan 29, 2014 3:45 PM UTC
Use trail files for batch conversion
Hi
I want to use trail files for converting files.
Right now every time I issue a trail command
which opens the file dialog it starts up always inside /users/<name of user>/documents
Is there a way to avoid and have creo use the directory form which it was run from, or maybe even specify the directory from where file open will start.
When I start creo using the command line, its working directory is the local directory from which the executable was called but the file open command always opens up inside /users/<name of user>/documents which makes it impossible to choose local files.
Thanks in advance
Dimi
DimiAnswer
Jan 30, 2014 11:59 AM UTC
Thanks fpr the reply,
after your suggestion I saw that I can create a config.pro file and put the
file_open_default_folder working_directory
For this I can either change the global config or create a local config.pro file.
Dimi
Jan 29, 2014 6:33 PM UTC
Are you trying to call Creo with the -nographics option?
Why don´t you just include in the beginning of the trailfile the "set working directory" command?
Dimi1-VisitorAuthor
Jan 30, 2014 12:04 PM UTC
I did not even know that there is a -nographics option... Right now creo openup normaly and shuts down again. This seams like a nice option. Do you supplu it on the command line? What other command line parameters can I use?
According to @Doug and from what i have read I can use the file_open_default_folder inside a config.pro file.
Are you suggesting setting as a command right into the trail file? If yes this is even better since the trail file will be self contained and not need a external config.pro file to function correctly.
How is the syntax of this command? Is there a doc for all available trail file commands?
Jan 30, 2014 10:08 PM UTC
Yes, is a good option if you are concerned with performance. Creo is much more faster working with this option on.
I have a aplication for batch processing too and is possible to run it in background. The disavantage is that you can´t see what is happening
I think this is how I called it from command line:
C:\Program Files\PTC\Creo 2.0\Parametric\bin\Parametric.exe -g:no_graphics trail_file.txt
In the beginning of the trailfine I define the working directory and that´s it, it works fine for me.
Doesn´t exist a document with trail file commands. These commands are generated when you are working with creo, and trailfiles were initialy created for recovery purposes, not for programming.
I suggest to read some articles at:
inversionconsulting dot blogspot dot com/2008/05/proe-anatomy-of-trail-file-part-1.html
Some good and rare info there.
Godd luck.
Jose
Jan 29, 2014 6:57 PM UTC
Look at the config optio "file_open_default_folder". I beleive the default is "my_documents", you want it set to "working_directory".
Dimi1-VisitorAuthorAnswer
Dimi
