Feb 10, 2016 8:26 PM UTC
Utilization of GPU in config, use opengl to increase simulate performance?
Greetings all,
     Long time reader, first time poster. I use creo 2.0 here at work and was running another FEA on a fixture structure, like normal, I monitor cpu and ram usage. I decided to watch the GPU usage and found that it sits idle the entire time I'm doing anything in creo. maybe a blip here and there when changing model display type, but am I wrong to think that there is some way to offload some of the computation to the gpu? While running simulate, my cpu is pegged wide open and appears to be throttling itself back whenever simulate has to read/write to the ssd temp files. While my new workstation is leaps and bounds faster and more powerful than my last workstation, I find it odd that I never really seem to make the K4000 graphics card earn its keep.
I have done a lot of searching and found various threads that touched on opengl issues, but it was usually in reference to an AMD card.
I've seen mention of such config options as:
graphics opengl
ENABLE_OPENGL_FBO
ENABLE_OPENGL_SHADER
ENABLE_OPENGL_VBO
USE_SOFTWARE_OPENGL
Is there anything obvious I'm missing? I appreciate and feedback or insight i can get.
Peter
system specs:
Intel Xeon E5-1620v2 @ 3.7 ghz
16gb ram
samsung ssd
nvidia quadro k4000
windows 7 64 bit
Creo 2.0 M130
Feb 11, 2016 5:59 AM UTC
unfortunatelly ProE/Creo is (and always was) not able to utilize GPU processing power.
MH
pmuzzy1-VisitorAuthor
Feb 11, 2016 12:25 PM UTC
Okay, I was kind of wondering this because i've monitored gpu usage and stats while doing a little of everything and haven't seen the gpu usage go over 20% for more than 1/10th of a second and only that when switching a very large assembly view display modes.
I know that Wildfire 4.0(which i prefer to use at all possible) performance is based almost entirely on single thread processing power, but with creo 2.0, more specifically creo simulate, it can make use of multiple processors. I know other programs and such can make use of the GPU power for computations, i.e. hardware acceleration, directcompute, scrypt-mining, etc. And with this Nvidia card's 768 cuda cores, it would be interesting to see how (IF) it could be used to help compute the thousands of small calculations in a FEA simulation.
So is there any real point or advantage of tweaking settings in the config to specify anything specific with the GPU or graphics in general? or not really because the gpu has enough horsepower to handle anything i can throw at it in any configuration so far?
Peter
Feb 12, 2016 6:02 AM UTC
ENABLE_OPENGL_FBO
ENABLE_OPENGL_VBO
ENABLE* options are used in case, when user has problems with graphic cards. They switch Creo functionality between old one (Wildfire) and new one (Creo). Example: Wildfire and Creo use different shading software algorithms.
USE_SOFTWARE_OPENGL
I guess that this option is obsolete. It was implement in times, when OPENGL was born.
MH
