Aug 18, 2011 3:59 PM UTC
version number on Pro/E files
Is there a way to turn off the dot number on the end of all of the Pro/E files?
To: top_case.prt
I was wondering if there is a hidden config.pro option.
Mark Nerby
Fluke Corporation
mark.nerby@fluke.com
Aug 18, 2011 4:21 PM UTC
No there isn't.
That's how ProE keeps track of versions. It even happens in your Windchill cache, but it's just hidden from you. If you use the workspace cache recovery tool you will see that all the versions are there.
David Haigh
Aug 18, 2011 4:31 PM UTC
The best you can do is a purge and then rename the files that are left.
Thank you,
Ben H. Loosli
USEC, INC.
Aug 18, 2011 4:34 PM UTC
You might be able to tell Windows Explorer to hide them in the folder
display, but then you'd have a whole bunch of files that appear to be the
same. Dangerous business.
efefefefefefef
Applied Research Labs
University of Texas at Austin
Carol Fly
Mechanical Designer
(512) 835-3397
Fax (512) 835-3259
efefefefefefef
_____
Aug 18, 2011 4:55 PM UTC
I need to ask. Why would you want to loose the extension?
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
Aug 18, 2011 5:14 PM UTC
If you were to do that, then your PC might think it's looking at UG-NX files. They end in .prt with no version number.
Bob
Dukane Corp.
Aug 18, 2011 6:21 PM UTC
Only if NX was installed after Pro/E. PTC takes the .prt extension, too, as the default open for file type.
Thank you,
Ben H. Loosli
USEC, INC.
