Jul 24, 2015 10:08 AM UTC
View label centralised
Hi All,
Please could you tell me if there's a config setting that I'm missing to centralise my section/detail view labels by default. I have this line in my dtl file:
default_view_label_placement BOTTOM_CENTRE
but they consistently still default to "right".
Andy
Jul 27, 2015 10:52 AM UTC
May be a simple thing...
the value should be "bottom_center" and not "bottom_centre"
Jul 24, 2015 10:44 AM UTC
Andy,
Assuming you changed your .dtl file, did you reload your updated .dtl file into your drawing?
I don't mean just to open the drawing, you need to physically reload your .dtl while in your drawing in order to make the new settings take affect.
I believe this should provide you with what you are looking to do, even with existing view labels. If not, try creating a new view.
ron
acoates1-VisitorAuthor
Jul 27, 2015 10:39 AM UTC
Hi Ron. The labels are still not central, even in new drawings. The .dtl isn't related to the sheet format template, is it?
Andy
Jul 27, 2015 10:44 AM UTC
the drawing will do a one time read of the .dtl file.  it will only update when you force another read.
hmmm, let me look some more....  you working in creo?
