Jan 30, 2015 11:15 PM UTC
VPN Issue
Hi - I have a user running a floating network license of Creo Parametric 2.0 on her laptop. At work, inside the firewall, everything is peachy. At home running VPN she gets an error "License request failed for feature" and cannot run the software.
After searching the PTC Knowledge Base I found this post<">http://communities.ptc.com/thread/40720> and tried renaming the registry setting for the network cards - without success.
This user has the same laptop as I do, same installation of Creo, same VPN software and yet I can connect and run the software but she cannot (I actually did a house call w/my system, connected to her wifi and ran Creo - but she could not.)
Suggestions? Thoughts? Suggested offerings to the CAD gods that might work?
-Ter
Terrence McFall
CAD Systems Administrator
Varian Medical Systems
Palo Alto, CA USA
650-424-6039 desk
650-799-0179 cell
Jan 30, 2015 11:53 PM UTC
With Windows 7 and above the user may get prompted to allow a service to be used on different types of networks. Is it possible that the user told the system not to allow the license manger access to the network?
Check the Firewall rules. I believe there is a way to reset it ifthey mistakenly blocked an app.
Michael Braaten
Senior PLM/CAX Systems Analyst - DePuy Synthes Companies of Johnson & Johnson
Jan 31, 2015 12:04 AM UTC
You might want to look at slides 41-43 of my the attendee version of my presentation. Not sure if they will help.
Jan 31, 2015 12:34 AM UTC
Just as a side note, I responded to the post on the PTC site with my suggested fix for the problem there.
You'll see it here:
StephenW
Jan 31, 2015 1:21 PM UTC
I saw that email come across from the community. I was REALLY surprised to see you post there.
Feb 4, 2015 2:53 PM UTC
I had a case where suddenly I could not remote login to my work PC from home.
Tried everything, updated Java, updated IExplorer to the latest version, and many other cleanings of old registry items but nothing helped.
The fix was for me to create a new Windows 7 user account in my home PC.
Once I logged into the PC with the new user name all the remote login problems to work were solved.
Give it a try.
Ronnie Shand
