Nov 30, 2012 5:35 PM UTC
Weird Workspace Error
I am a first year engineer student who has recently started using Creo Parametric 2.0. When I installed the program in my computer (windows 😎 all the apps installed correctly. The only problem is that when i try to model something the workspace is like mirrored (You read top, right and left as if it was in a miror, as shown in the image below).The thing is the mouse also acts as mirrored, meaning that when i try sketch something in the bottom bit it appears in the top bit an vice versa. Any solution?
Nov 30, 2012 6:16 PM UTC
Greetings Ignacio,
I would suspect it's an issue with your PC. It doesn't appear that Creo 2 is supported on Windows 8 yet. See here http://www.ptc.com/WCMS/files/135225/en/creo2_hw_notes.pdf
You might try setting your graphics to win32_gdi.
Dale_Rosema
Nov 30, 2012 7:25 PM UTC
Ignacio,
Check out this discussion and see if it helps resolve your issues:
http://communities.ptc.com/message/192374#192374
Dale
Nov 30, 2012 8:03 PM UTC
Joshua and Dale,
I changed the graphics to win32_gdi and now the workspace is correct.
Thank you a lot for your help!
