Jan 6, 2015 6:44 AM UTC
Welcome window should not open in each start up.
How to stop the opening of welcome window in Creo 3.0?
Welcome window is opening in each start up of Creo 3.0.
Kindly provide the solution.
Jan 6, 2015 11:32 AM UTC
At the bottom of that window you have a checkbox with option to put welcome screen into a built-in browser. When you check it, welcome window will load as one of the browser tabs instead of popup window.
vpatel1-VisitorAuthor
Jan 6, 2015 11:42 AM UTC
Thank you Lukasz Mazur. It is done.
Mahesh_Sharma
22-Sapphire I
Jan 6, 2015 7:07 PM UTC
Viral,
You may mark Lukasz's answer as correct answer.
