Apr 2, 2012 2:23 PM UTC
WF 2.0 and Win 7 64bit
Has anyone been able to install WF 2.0 on a Win 7 64 Bit machine? I was trying to do that and I couldn't even get it to execute the setup file. Any insights would be great...
Michael Wimberly
System Administrator, Sr
Intelligence & Security
T 513 881-4843 | M 513 833-3565 | F 513 881-5087 | -<">mailto:->
www.baesystems.com
Apr 2, 2012 2:32 PM UTC
Hi Michael,
It is an extra step but you can install Wf2 on a 64-bit XP machine and
then just copy the entire loadpoint directory to the Windows 7 machine and
manually add it to the Path environment variable.
Personally, since Pro/E is somewhat self contained, I just add the path to
the launch bat file in the bin directory.
Example:
@echo off
set Path=C:\PTC\Wildfire2_64_M220\bin;%Path%
C:\PTC\Wildfire2_64_M220\bin\proe.exe
C:\PTC\Wildfire2_64_M220\bin\proe1.psf %*
This has worked for me for many years.
Respectfully.
2-Explorer
Apr 2, 2012 2:35 PM UTC
I have found that you need to install the 32 bit version. Unless you are
creating huge, complex assemblies, WF2 will clip along quite nicely.
I am happy to see that I am not the last person on earth still using WF2.
-Nate
