Feb 18, 2010 7:59 PM UTC
WF3 and WF5 on same machine
I'm pretty sure I've seen this question and I'm also pretty sure that it
works but I want to be sure.
Can be run both WF3 and WF5 from same machine on a server license?
We intend to run both for a while as a transition to 5. (Of course without
saving in WF5)
Thank you!
Luke DiVenti
Feb 18, 2010 8:19 PM UTC
As long as you install WF3 and WF5 in different directories, they can run on
the same machine. Make sure the license server has the most up-to-date
license file, though.
Zack
On Thu, Feb 18, 2010 at 12:59 PM, Luke Diventi <
> saving in WF5)
> Thank you!
> Luke DiVenti
Feb 18, 2010 8:21 PM UTC
Luke,
All the Pro/ENGINEER licenses are downward compatible which
means a person having a license for
Wildfire 5.0 can work with WF4, WF3, WF2, WF and 2001, but one at a time.
In your case, if you have 2 license of Pro/ENGINEER available
then you can launch WF5 and WF2 simultaneously else you have to launch one
after another.
~Ash..
Feb 18, 2010 8:23 PM UTC
In addition to it,
If one has locked license of Pro/ENGINEER then one can launch any number of sessions of Pro/ENGINEER irrespective of releases.
Feb 18, 2010 11:10 PM UTC
Yes.. Borrowed License acts as locked license and any number of sessions can be launched.
But if WF3.0 is borrowed then only WF3.0 sessions can be launched.
