Jul 6, 2010 7:56 PM UTC
what directory should config.win be installed
what directory should config.win be installed???
Thanx Steve Norwood
Jul 7, 2010 7:31 AM UTC
That depends:
If You want global settings for all users, put it in the <proe-install>/text folder.
User-specific settings are best in the working directory. That file should only contain changes wrto the global settings.
If You have different user settings, copy the file to the working directory before starting ProE. (Remember, ProE will add an index when local changes are made.)
Jul 7, 2010 1:33 PM UTC
Great reply by Harald. Just wanted to add that you can automate all this with a script to make life easier.
