Apr 25, 2013 12:39 AM UTC
What is the merit of using PRO-E(32 bit) over 64 bit PC than 32 bit PC
It was found that over a 32bit PC the maximum RAM(memory) can be used for processing is atmax 4GB.
Is there would be advantage that using 64bit PC the RAM could be used up over 16GB (or more ,the maximum capacity of RAM available for any pc)
Or
Even if Using 64bit PC ,a Pro-e( 32bit) could be processed only 4GB regardless of the maximum capacity of RAM(suppose 16GB ram is installed in PC)
If there is no utilization of more than 4GB in a 64bit PC (in case of 32bit proe software) ………There is no necessary to change into 64bit PC
