7-Bedrock
May 13, 2025 8:48 AM UTC
What steps to be taken upgrading from EMX 9 to EMX 10
My client are using Creo 9 with EMX 9.0 which has some configurations added on config file.
Now Creo is upgraded to Creo 10.0 and EMX 10.0 is also installed.
But when opened Creo 10.0 it shows error message of config settings file.
Need help what changes to be made for using EMX 10.0 with Creo 10.0
Rahul Sardar
Mahesh_Sharma
22-Sapphire I
May 22, 2025 2:26 PM UTC
Hi @rahulsardar1
Config option protkdat with value pointing to protkdat for EMX is the one which configures EMX with Creo. If it exists in your config you can remove that.
I think sharing some details about the options which will not work, can help understanding the issue better.
Thanks.
Emeritus
May 20, 2025 8:33 AM UTC
Hi @rahulsardar1,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team.
Mahesh_Sharma
22-Sapphire I
May 21, 2025 9:04 PM UTC
HI @rahulsardar1
Creo 10 has inbuilt EMX 16.0 which needs to check to include when installing Creo Parametric. If your customer has valid license for EMX simply include EMX in Creo 10 install and use. This process doesn't need any external configuration.
I hope this will help.
7-Bedrock
May 22, 2025 4:57 AM UTC
Thank you for the update Mr.Mahesh.
I am aware that Creo 10 installation is part of Installation setup.
But when i use the Creo 9 config file for Creo 10 , it gives message of few options won't work.
Need help to understand what changes needs to be made for use in Creo 10
Mahesh_Sharma
22-Sapphire I
Hi @rahulsardar1
Thanks.
Emeritus
May 22, 2025 4:03 AM UTC
Hello @rahulsardar1,
It looks like you have a response from a support expert. If it helped to answer your question, please mark the reply as the Accepted Solution.
Vivek N.
