When user is saving the file to .stp or .iges, its time consuming.
I am using Creo Parametric Release 8.0 and Datecode8.0.4.0
Hi Team,
When user is saving the file to .stp or .iges, its time consuming or no response fro Creo parametric.
It takes more time than the other user, sometime no response.
    tbraxton
    This looks like another technical support request that was routed to the community. If you intended to post to the community, you have not included relevant information needed to solve your issue.
    If you intended to open a call with support, you were not successful go back to this link and make sure to open a case and not post to the community.
    https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
