Where is Creo Chromium-browser-cache located?
I am using Creo Parametric Release 11.0 and Datecode11.0.6.0
Unable to find where Creo Chromium-browser-cache is located for Creo 11.0.6.0 on the client to be able to clear it at every Creo start.
    20-Turquoise
    If PTC_WF_ROOT is not set then the cache is in:
    %LOCALAPPDATA%/PTC/Creo/Platform/Zbrowser
    if PTC_WF_ROOT is set then the cache is in:
    %PTC_WF_ROOT%/.ssrd
    20-Turquoise
    %PTC_WF_ROOT%/.ssrd
    C4DG33K10-MarbleAuthor
    Hi RandyJones, thanks for swift answer.
    PTC_WF_ROOT is set.
    Now tested, deleting the .ssrd folder did clear the browser cache!
    20-Turquoise
    PTC_WF_ROOT is set.
    So, deleting the .ssrd folder or everything in it, at Creo start should clear the browser cache!?
    Yep. We do the same thing with a custom Creo Parametric startup .bat.
    You can verify the location by typing chrome://version/ into the browser address bar and it will give you that as well as other information.
    Thanks for the reminder, now when you mention it, I remember I've used that method before. 👍
    FYI - Within the embedded browser in Creo Parametric, enter the address "chrome://version/".  It will display information about Chromium which includes the full cache path.
    Dan N.
