Whether Creo Parametric 4.0 embedded browser supports 64-bit
As I know, Creo Parametric 3.0 only supports 32-bit embedded browser
18-Opal
January 6, 2017
Hi Lie Feng Jin,
In Creo 4.0, we have increased the embedded browser process support to 64-bit for both IE and Chromium.   Note: The browser for Creo 4.0 will only support a 64-bit. An additional enhancement in Creo is that the embedded browser will be run as a separate process by default.
Mark
Mark,
I'm using Creo Parametric 4.0, M030. The embedded browser is not a separate process! When I open a new Creo, it connects to the server right away. When I change the workspace in one Creo session, it's changing the workspace into other Creo to. This is a problem when I try to open 2 assemblies into different Creo from different workspaces. It can not be done.. Any suggestions?
Thank you,
Mike
Creo can only be activated to one Workspace at a time. This is the functionality of Windchill. It helps Windchill workspaces from getting corrupt due to the cache location on your C: of 😧 drive.
