Why does Creo 2.0 and 3.0 not works with Geforce GTX 960M ? How can i solve it ??
How can help me?
    you posted your question on Creo/Elements Direct area. Do you use this software or Creo Parametric ?
    MH
    rreupke1-VisitorAuthor
    I use Creo Parametric.
    what happens, when you launch CR2/CR3 ?
    Do you use PC or notebook ? What configuration ?
    Which version of graphic card drivers is installed ?
    Tip: Add following option at the end of config.pro file and do test.
    graphics   win32_gdi
    MH
