Sep 27, 2010 11:37 AM UTC
window 7 license borrow
just got new machine with windows 7 64 bit. cant borrow license. what can i do to fix this. i borrow quite often for my job.
thanks
Daryl
Sep 27, 2010 1:23 PM UTC
For whatever reason when we execute the "proe_borrow.bat" we have to run it as administrator. If we don't we get an error that the "proe.exe" can not be found. When we select the "proe_borrow.bat" RMB and select "run as administrator". This will allow us to execute the license borrowing without issue. Hope that this helps.
DarylWolf1-VisitorAuthor
Oct 20, 2010 1:49 PM UTC
Brian, this works to borrow the license but then when I open pro it tells me deleted borrowed license and it wont open. Am I missing something else to the trick. After I borrow the license I exit pro , shut my machine down, then when i get home and want to open it i turn it back on and start proe. Is there something I do different than you and your pattern.
Thanks again.
Oct 20, 2010 2:24 PM UTC
Daryl,
Here is the process that I follow. I execute the license borrow and when Pro comes up I grab any floating modules that I want to borrow (usually a manufacturing license). I then close Pro and turn the system off. I haven't ran into any issues with the license not being borrowed, so I really don't have any insight into what could be causing your issue.
