Jan 21, 2010 8:32 PM UTC
Window size
Some dialog boxes cover the side toolbars of the window. Is there a setting that can reduce the width so this doesn't happen? See the attached pic.
    Jan 21, 2010 8:36 PM UTC
    Here's the pic. I'm posting as a link because the "Add an Attachment" functionality of this forum sucks.
    Jan 22, 2010 12:49 PM UTC
    Try the "reserved_menu_space" option (value 1.0 to 4.0). I cannot give you the correct value for your specific window right now since I have now WILDFIRE at hand. Just play with the value until it fits.
    Jan 22, 2010 1:22 PM UTC
    Thank you. This works exactly the way we want. Now, to make it more complicated.... if we have 2 monitors can we set this value so the reserved menu space is zero in the main window and the dialog boxes go onto the window to the left?
