With each Creo+ update, the "Start in" setting is reset to the default
Issue is that with each Creo+ update, the "Start in" setting is reset to the default.
KenFarley
I'm uncertain how Creo+ is updated, or how frequently, but this is typical behavior when updating software that relies on a "Start In" directory specification in the shortcut. Unfortunately requires a bit more understanding of how things work for people. The really bad part of this is that at my company I need to have temporary admin privileges to install/update any applications, so any shortcuts are created by an administrator, which I am not. If I later realize I need to change these types of settings, I can't unless I again get a temporary admin password.
Creo+ is SaaS and not It is common software, I should be free from all kinds of installation issues. My understanding is that we install once and everything else is updated behind the scenes.
from my point of view Creo+ is not full-fledged SaaS because it is running on user's computer (not in the cloud as Onshape).
