Jun 10, 2014 3:08 PM UTC
Working with Interchange Assembly and Family tables
Hey guys,
I am wondering if there is a solution for what I want to accomplish....
I have a interchange assembly with some parts that are similar, but within my family table on the upper assembly is there a way I could basically say, hey I want this part in my interchange assembly.
I realize that I can do a replace within my upper assembly and choose a different part.... BUT can I do that same option within a family table on the upper assembly, so that when I open a instance it shows various different configurations of my interchange assembies.
I know that within the upper assembly if I want to replace a componant with a different instance I can do that but could i do the same thing with interchange possibly thru a user defined feature? or relation?
Jun 11, 2014 8:20 PM UTC
Brock,
I am not sure I get all the details in your question, so just refering to the 2nd passage :
you surely can replace top level component (part or subassembly) by its Interchange "buddy". What you need to do is to :
1. add this top level component to Family Table as an item
2. In respective top assembly instance cell in tghe table, go to Tools / Replace BY / Interchange - and browse to the needed interchange component.
3. Your instance of assembly will contain the interchanged comp. now.
Let me know if your intent was for something different.
Regards
- Vlad
bwudtke1-VisitorAuthor
Jun 12, 2014 12:35 PM UTC
Thanks for your input, but i figured it out the other day. I wasnt aware that you could use interchange assemblies as a column in your family table.
