TomU
Jun 13, 2014 5:58 PM UTC
"works to product specification" - who writes these things???
Saw this come through today: https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS174472
Who writes these things? Why would anyone write a product spec to randomly name files when batch printing?
I could understand if they said, "oops, we didn't think about that", but instead, "we designed the product to name your files is such a way so that you have absolutely no idea what they are." Really?
Jun 14, 2014 12:57 AM UTC
The specification didn't exist before you complained... but now that you complained, miraculously, it does exist, -and- what do you know, it meets it -perfectly- !
Jun 23, 2014 8:51 PM UTC
Hi Tom,
Thank you for bringing this to our attention. I've pulled this article from the public domain and submitted it for rework by an engineer in that product area.
In the future, the "Did this document help you?" feedback widget is available in the lower right to let us know how such documents can be improved.
TomU
TomU23-Emerald IVAuthor
Jun 30, 2014 6:52 PM UTC
Here is another one that came out today. Seems like a similar issue.
https://www.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS175394
I find it hard to believe that the product specification actually spells out this behavior. It seems more likely that this is undefined in the spec., and therefore automatically considered in compliance (since no other behavior is specified). Absence of pre-defined behavior in the spec. shouldn't equal compliance, especially when the resulting behavior is completely illogical (unless it really isn't).
I guess the root issue is this, if tech support is going to tell me something "works to product specification", then I expect them to be able to produce that portion of the specification both proving it and explaining the "why" behind it. Doing so would help us understand the software better and maybe even show us new/better ways of using it.
2-Explorer
Jul 6, 2014 4:01 AM UTC
How long would it take for the database Admin to make a search of that database for "Works to product specification" and flag each one that doesn't link to the applicable product specification? Years, probably.
Jun 30, 2014 9:24 PM UTC
Several years ago I was sitting at the PTC User conference over lunch with the head of tech support. I expressed my frustration with the canned "intended Functionality" response, which is what they used to say instead of "works to product specification". He told me that if the support rep tells you that he ought to be able to produce documentation to support it. Ask to see it if you think he's simply trying to close the case without action.
18-Opal
Jul 30, 2014 8:54 PM UTC
I have asked on several cases to produce documentation, but even on the cases where I think it was legitimately accounted for they have never produced any kind of documentation. When pressed they just tell me what R&D said, and their reasons. Have you ever had success asking for this? And if so how do you word it?
TomU
Jul 30, 2014 9:09 PM UTC
Frankly, no, I've never actually gotten anything back. The closest I've come is receiving custom written documentation from R&D explaining certain aspects of Pro/e that were (and still are) undocumented. Making the request for proof does help me move cases to higher level personnel who often have a deeper understanding of the software. The vast majority of the cases I open end with the tech saying, "please create an idea on the PTC community". I don't think I've ever been told "why" something is a certain way. I'm slowly learning that "why" really doesn't matter. Instead I make sure I really understand how it is supposed to work, then either submit suggestions to change it, or find a way to work around it.
Jul 7, 2014 11:08 PM UTC
It is fine.
TomU
Mar 17, 2017 7:58 PM UTC
Here's another one.  It's like the people writing the spec's don't actually use the software.  I just don't get it.
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS219704
22-Sapphire I
Mar 17, 2017 8:02 PM UTC
You know you're dealing with tech support when you see "Works to Product Specification"
You know you're dealing with Marketing when you see "You know, this is a valuable feature and we're going to charge extra for it"
TomU
Mar 17, 2017 8:17 PM UTC
I'm less frustrated with tech support and more frustrated with the person who wrote the spec.  Why in the world would someone go to the trouble of making it possible to display an image on a part but then not have it display on all the copies of that part in an assembly?  Maybe there is some good reason.  I just can't figure out what it would be.
