请问怎样增加文本字体?How to add text fonts?
  • September 10, 2015
  • 15 replies
  • 5953 views
你好,请问怎样增加文本字体?如能帮忙十分感谢。
Hello, how can I increase the font size? Thank you for helping me.
    Best answer by MartinHanak
    if you add the following option into config.pro file, then you will see all Windows fonts in Drawing mode.
    PRO_FONT_DIR C:\Windows\Fonts
    Alternatively, you can copy .ttf files from C:\Windows\Fonts directory to Creo2_loadpoint\Creo 2.0\Common Files\Mxxx\text\fonts directory.
    If you want to set text height in the drawing, then:
    • select text
    • press right mouse button
    • use Properties command
    • set height on Text Style tab in dialog window
    Martin Hanak
    please provide more details (text, picture)...
    Martin Hanak
    jchen-61-VisitorAuthor
    Hello, I want to add the font style in the drawing,
    Thank you
    • select text
    Martin Hanak
    18-Opal
    September 10, 2015
    Hi Jack,
    Are you looking to increase the font size of notes/text in the drawing or maybe the font size of the menus in the Creo window?
    Please clarify what you are looking for.
    Thank you,
    Amit
    Thank you
    you just click Edit>Font> increase or Decrease
    I can't find the Edit
    18-Opal
    September 18, 2015
    Hi Jack,
    I just wanted to check if my suggestions above helped you get the desired result.
    If not, please let me know any further information, that would be useful to help me find the answer.
    Amit
