Sep 21, 2022 8:32 AM UTC
Creo 7.0.9 update not working
Hej everyone!
I am running Creo 7 and have tried several times to apply the latest updates.
I have administrator rights on my computer.
When I start the setup file I get no error message, nothing. But the file starts somehow and then nothing happens.
How do I fix this?
Greets from Sweden!
Björn
Sep 21, 2022 1:14 PM UTC
I had no issues with installing Creo 7.0.9.0. I run Setup as Administrator. Being in the administrator group isn't enough for Windows 10+. Right click on Setup.exe and the Run as Administrator,
If that still fails, try removing your old build of Creo 7 and do a clean install of 7.0.9.0. By default, Creo installs each build in its own directory anyway.
Sep 22, 2022 1:25 PM UTC
I tried to run it using "run as administrator". No luck here.
Once I have time I try a clean install.
