3-Newcomer
Oct 9, 2024 11:47 AM UTC
Silent install for Flexnet
is there a possibility to install Flexnet license server silently on Windows Server Core 2022?
or even install it on Windows Server Core 2022?
br Bernhard
Catalina
Community Manager
Oct 14, 2024 10:10 AM UTC
Hi @bmüller,
Thank you for your question.
Your post appears that has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do. Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Best regards,
Catalina | PTC Community Manager
Oct 18, 2024 8:09 AM UTC
i am also intrested in a silent install for FLEXnet Admin Version 11.19.6.1.
Is there a known way to do it?
I know the way to install PTC Creo Parametric silent for example is to start the setup.exe with the -xml parameters. E.g.:
"SOURCEPATH\"setup.exe" -xml "SOURCEPATH\pim\xml\creobase.xml" -xml "SOURCEPATH\pim\xml\pma.xml"
In the source from the FLEXnet Admin is also a pim\xml\flexadmin.xml file, but when i start the setup.exe from the source of FLEXnet Admin with the parameter to the given .xml-file i always get an errorcode -1.
I think this has to do with the missing license.dat file which i need to browse in the gui installation.
Is there a way to define the license.dat file in the pim\xml\flexadmin.xml or to define the license.dat file as a parameter?
Thank you in advance.
Best regards
Oliver
bmüller3-NewcomerAuthor
3-Newcomer
Jun 11, 2025 8:41 AM UTC
Hi, I couldn't find a solution yet. Especially with the need to uninstall and install on every upgrade, it would be nice to script it.
Jun 11, 2025 11:57 AM UTC
Article - "How to install Flexnet license server in silent mode": https://www.ptc.com/en/support/article/CS434707
