91104643 [JBoss Logger] ERROR mksis.IntegrityServer - * * * * ERROR * * * * (0): mks.si.api.SIAPIException -- mks.si.api.SIAPIException: Project with same name already exists
I am seeing the below error in the eventvwr on the server where MKS is setup.
Event Source: MKS Integrity Server
Event Category: Error
Event ID: 4096
Description:
at mks.si.brain.cmnative.NativeServer.checkNewArchiveName(NativeServer.java:1100)
at mks.si.brain.cmnative.NativeCMArchive.ensureCMArchive(NativeCMArchive.java:138)
at mks.si.brain.cmnative.NativeMember.doCheckIn(NativeMember.java:370)
at mks.si.brain.cmnative.NativeMember.writeRevision(NativeMember.java:326)
at mks.si.brain.cmnative.NativeMember.checkIn(NativeMember.java:278)
at mks.si.brain.api.LocalMember.newMemberCheckIn(LocalMember.java:1925)
at mks.si.brain.api.LocalProject.addMemberInternal(LocalProject.java:2956)
at mks.si.brain.api.LocalProject.addMemberInternal(LocalProject.java:2496)
at mks.si.brain.api.LocalProject.addMemberFromFileV2(LocalProject.java:2389)
at mks.si.brain.api.LocalProject.addMemberFromStreamV2(LocalProject.java:2333)
at mks.si.brain.api.LocalProject.addMemberFromBulkDataV2(LocalProject.java:2359)
at mks.si.brain.api.LocalSandbox.addMemberFromBulkDataV2(LocalSandbox.java:323)
at sun.reflect.GeneratedMethodAccessor326.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.sapia.ubik.rmi.server.invocation.InvokeCommand.execute(InvokeCommand.java:185)
at mks.ubik.transport.beep.BeepServer$2.call(BeepServer.java:359)
at mks.ubik.transport.beep.RmiInvocationAction.call(RmiInvocationAction.java:152)
at mks.ubik.transport.beep.BeepServer.executeCommand(BeepServer.java:375)
at mks.ubik.transport.beep.BeepServer$1.call(BeepServer.java:313)
at mks.ubik.transport.beep.BeepServer$1.call(BeepServer.java:310)
at mks.rmi.RmiAuthenticationHandler$1.run(RmiAuthenticationHandler.java:90)
at java.security.AccessController.doPrivileged(Native Method)
at javax.security.auth.Subject.doAs(Subject.java:396)
at mks.rmi.RmiAuthenticationHandler.doAs(RmiAuthenticationHandler.java:95)
Please let me know if anyone knows about it.
Regards
