About JAVA API
Can anyone help me through JAVA API i have couple of task what we can acheive from JAVA API's ?
KaelLizakAnswer
Hello @kjain-2,
That's a fairly broad question.  Please see the Integrity Integrations Builder Guide.  Page 73 lists the command line commands which are implemented by this API.
This thread provides a common example:  getting the results of an Integrity query.
I hope that helps.
Kind Regards,
Kael
KaelLizak16-PearlAnswer
Hello @kjain-2,
I hope that helps.
Kind Regards,
Kael
kjain-21-VisitorAuthor
Hi @KaelLizak,
Very first a big Thanks for your quick response...
As i got a task that i need to be acheived via JAVA API that's why i wrote but this documentation looks very good i'll go through this once and will get back to you if required.
Thanks @KaelLizak.
Kapil
Hello @kjain-2,
It's been about a week since your last post.  Did you have any follow-up questions?  If not, could you accept the correct reply to your post as an accepted solution, so that others browsing threads can see this has been resolved?  This will make it easier for later searchers to find the solution to their problem if it's the same as yours.
Kael
