Add change package entries?
ist there a way to add change package entries to an existing change package?
Example:
A user missed associating a checkin or set member rev with a change package (we have no mandatory change packages in all projects).
Can he create a change package afterwards and somehow add the checkin and/or set member rev action?
I have seen that you can discard change package entries, but obviously not add them!?
    Hi Stephan,
    Can you clarify your scenario?  Did they already check-in and commit their change, without the change package?  If so, then you can't add that action to the change package after the fact.
    He'd have to do a new check-out/check-in and associate with a change package.
    If they yet have to check-in, he should be able to pick a change package at check-in time, depending on your change package settings, if he didn't pick one at check-out.
    Some clarification/screenshots may help.  But if you've already committed a change to your repository, without a change package, you can't after-the-fact, say it was part of a change package.
    Hi Stephan,
    ssaul15-MoonstoneAuthor
    Hi Michael,
    unfortunately, the changes are already done/committed without a change package.
    The user wants to correct this afterwards.
    I thought there might be the opposite action to discard change package entries, but obviously it isn't.
    Thanks for clarification anyway!
    Maybe a stupid Idea (never tested this):
    If its just to leave some traces in a apropriate change package he could try to apply Update Member Revision to
    the revisions he checked in (in the order they were created) using a newly created change package (the best case would be I he would land
    on the current revisions after this).
    This might be problematic if other users have already checked in new revisions (with Update Member Revison option).
    BTW:
    If the use case was that checkins used the wrong change package the I guess Move Change Package Entry
    might be the way to go.
    Regards Jürgen
