ALM CheckList
There is an ALM checklist, that's created and tasks are using this checklist.
 Would an update to this ALM checklist to new parameters effect the tasks that were started or closed.
Hello Ram,
I am sorry, but the use case you are describing is not clear to me.
Would you mind telling us a litte bit more what you are trying to achive with Checklists, Tasks, Parameters?
How does your setup look exactly?
Volker
there is an ALM checklist, that is been used by the ALM tasks.
I want to modify the checklist with new check items.
Will updating the existing checklist to new check items effect the ALM tasks that are already using them.
The reason for not creating a new checklist item is to use a single checklist across the project.
One more Question: Is your checklist an Integrity Document (I would suggest!)?
If yes, you can create a branch when updating or adding check points to prevent from affecting existing checklists/ALM tasks.
But, do you want this update or you don't?
