An easy scripting question...
Is there an API, or easy method, to get the numeric value associated with the string value of a Pick Field?
    Hi Sean,
    Have you looked at the imFieldBean? It has a method that sounds like it will do what you want:
    getPickFieldMappings()
    If getFieldType() is the value "pick", then this method will return a mapping of the display strings to the underlying numeric pick values.
    Wouldn't using the im command work?
    im fields --hostname=<your-host> --fields=type,picks,name
    You could redirect it to a log file and extract the values from the pick types.
    That would be harder than what I'm doing at the moment; which is hard-coded string lookup tables. I was hoping that there was an easy API call to use instead of getFieldValue.
    I'm in a trigger script and need the numbers to perform calculations. So dumping the values to a log file really isn't a practical option.
    Thank you for the idea, though.
    Hi Sean,
    Thank you, Joe. That will do it.
