branch locking
How can I lock down a branch in Integrity ?
    mrumpAnswer
    Create a new specific ACL for your Dev-path and restrict the "checkin" permission as needed.
    HTH
    Matthias
    Hi Hector,
    I'm not shure want you mean.
    Do you want to place a Lock on all members in a project's development path?
    > use "menu/project/open" to open a view on the project's devpath you desire; select the top project and "Lock" the members recursive.
    Do you want to prevent Members in a project's development path from being changed?
    > use "menu/project/open" to open a view on the project's devpath you desire; select the top project and "Freeze" the members recursive.
    > use "menu/project/open" to open a view on the project's devpath you desire; create a chekpoint on the project to store the current projects setup (for ever in a read-only way)
    Please specify your use case!
    HTH Matthias
    hmagnanao1-VisitorAuthor
    Hi Matthias,
    Thanks for your reply. I want to prevent users from checking in into the dev branch in question. So which would be the best and quickest option of the three above ? And is there a command line equivalent ?
    Hector
    mrump16-PearlAnswer
    HTH
    Matthias
