Can I add a sum to a stacked bar chart at the top of each bar?
Hello all,
I created some charts for my dashboard. Each chart is a "vertical stacked bar graph". Can I add a sum to each stacked bar in the chart at the top of each stacked bar?
Thank you for your help,
Christian
    Hello Christian Brendler‌,
    I'm not sure exactly what you're asking. Could you give us a more detailed explanation of what you are trying to do?
    Kael
    cbrendler1-VisitorAuthor
    Hello Kael,
    thank you for your answer.
    Let me show you a screenshot.
    I have created this Chart. The numbers of each result is printed in the bar.
    I would like to print the sum of all bars on top like I drawed the 32 and the 2.
    Christian
    Hello Christian,
    Thanks for clarifying!  I completely misunderstood where you were going for with that.  Unfortunately, what you're asking for is not possible within Integrity.  You could create a Product Idea to propose this as a new feature.
    Alternatively, you could export the data to Excel, and use Excel charting (assuming it can do this)
    Kael
