Can I open the 'View Documents' on second monitor?
When I create a trace between two documents, I opened two documents in same monitor.
I use dual monitor now.
If one document windows was opened in main monitor and another document window was opened in second monitor, it is more comfortable for me.
    Hello Yousun Sohn,
    what we need is a custom menu entry, with the following code behind.
    im viewsegment --user=%MKSSI_USER% --gui %MKSSI_DOCUMENT%
    It can be inside a simple batch file, or a powershell script, or a small java program (that's what I did).
    Hope this helps, any followup question is welcome.
    Volker
    Hello Yousun Sohn‌,
    This is not currently nicely handled by the Integrity client.  Please open a ticket with PTC Integrity Support to add your organization to CS91123.
    Kael
    Hello Yousun Sohn,
    Volker
    Hello Yousun Sohn‌,
    Did Volker Eckardt‌'s answer resolve this issue for you?
    Kael
    ysohn1-VisitorAuthor
    Thanks for your helping!!
    Your solution is good for me
