Can't install PTC System Monitor agent
Does anyone have any idea what I am doing wrong? I have installed the server and collector on a Windows server without any problems, but when I come to install the agent for monitoring the integrity server on a Linux machine, it always fails:
Log file:
java.lang.NullPointerException
    at com.ptc.windchill.psm.agents.configration.IntegrityConfiguration.install(IntegrityConfiguration.java:252)
    at com.ptc.windchill.psm.ia.IAInstaller.install(IAInstaller.java:120)
    at com.zerog.ia.installer.actions.CustomAction.installSelf(Unknown Source)
    at com.zerog.ia.installer.InstallablePiece.install(Unknown Source)
    at com.zerog.ia.installer.GhostDirectory.install(Unknown Source)
    at com.zerog.ia.installer.Installer.install(Unknown Source)
    at com.zerog.ia.installer.actions.InstallProgressAction.af(Unknown Source)
    at com.zerog.ia.installer.actions.ProgressPanelAction$1.run(Unknown Source)
DEBUG  2015-08-27 14:07:08 - **********************************************************
DEBUG  2015-08-27 14:07:08 - PTC System Monitor agent installation failed: PTC Integrity Server
DEBUG  2015-08-27 14:07:08 - Installation log file location: /tmp/installer/logs/PTC_SYSTEM_MONITOR_40_F000_PtcInstall.log
DEBUG  2015-08-27 14:07:08 - Retrying Installables deferred in pass 0
DEBUG  2015-08-27 14:07:08 - Deferral retries done because:
DEBUG  2015-08-27 14:07:08 - There were no deferrals in the last pass.
DEBUG  2015-08-27 14:07:09 - Did not match to message method
DEBUG  2015-08-27 14:07:34 - SHUTDOWN REQUESTED
DEBUG  2015-08-27 14:07:34 - (X) commiting registry
DEBUG  2015-08-27 14:07:34 - REGISTRY ALREADY STORED!
DEBUG  2015-08-27 14:07:34 - (X) shutting down service manager
DEBUG  2015-08-27 14:07:34 - (X) cleaning up temporary directories
DEBUG  2015-08-27 14:07:34 - Exiting with exit code: 0
I am using the GUI to do the install but it fails whether I use root or the Integrity user. I've already wasted a day on this so would really be appreciative of any help.
Best regards,
Paul
    2-Explorer
    In the the <Integrity server install directory>/config/mksservice.conf file
    Try removing the quotations around mks.java.additional.XX=-agentpath:"<PSM Agent install path>\libdtagent.so"=name=<local name>,server=<server name: server port>,wait=15
    Binesh Kumar
    Barry Wehmiller
    2-Explorer
    "Increase Integrity JVM Timeout to 10 minutes" box in the "JVM Timeout section"
    Edit <IntegrityServerInstallDir>\config\mksservice.conf
    Set the following property:
    mks.ping.timeout=300
    Also please make sure you have enough space /tmp
    Binesh Kumar
    Barry Wehmiller
    padams1-VisitorAuthor
    Thanks for the info.
    ping timeout was already set and trying to set JVM Timeout to 10 minutes then returned a message box that it would not be set as I have less then 8GB heap space, which I already knew. However it then installed!
    The next problem is that my Integrity server will no longer start. The JVM stops immediately:
    From startup.log:
    STATUS | 2015/08/27 15:48:35 | Launching a JVM...
    ERROR  | 2015/08/27 15:48:35 | JVM exited while loading the application.
    and repeats until the mks.max_failed_invocations setting is reached.
    restoring the old mksservice.conf allows the server to start normally
    Any ideas?
    Best regards,
    Paul
    2-Explorer
    Binesh Kumar
    Barry Wehmiller
