Can we create a user using a trigger or Java code
Hi Guys,
I need to create a user using a trigger is it possible ?
If yes can you tell me how ?
If no cab you tell me the reason ?
Shree
ShreeAnswer
yes, the user will be imported from LDAP, but the account is active only when the user login into the integrity for the 1st time.
For my business:
There will be certain user's how wont use Integrity. Such user data wont be available in the Integrity. So i need to add them into integrity.
Sure, you can.
If not part of the trigger bean, you can always call the related API command.
Just for interest: why you need to create a user in a trigger? Usually users will get imported from e.g. LDAP.
So you will have to import them or assign them to groups only.
Shree1-VisitorAuthorAnswer
For my business:
I am using 2 steps to "Import" a user from LDAP:
1/
integrity editmksdomaingroup --user=<execution user> --hostname=<host> --addMembers=u=<NewUserId> "GroupNameToAddTo"
2/
im importuser --user=<execution user> --hostname=<host> <NewUserId>
Then, this user is available in Integrity W&D.
Perhaps this helps.
Volker
PS: I could perform also both steps in the UI, but the command line is much much faster 🙂
