"cannot convert null to an object" in a triggerscript
Hi @all,
i'm now outing me as a non-programmer
We have following problem: in an item were three datefields. The first field should be filled by the user, and the other two fields should be computed by a rule. Because filling a datefield by a computation it is not editable anymore we wanted to use a trigger to do this.
This works fine unless the user doesnt fill the first datefield. Then we get a javascript error:
"Internal Error: undefined: Cannot convert null to an object."
Here comes the code from the triggerscript:
try
var issue = bsf.lookupBean("imIssueDeltaBean");
var params = bsf.lookupBean("parametersBean");
var fieldDueDate = params.getParameter("Startfeld");
var CompValue = params.getParameter("Anzahl Tage");
var targetField = params.getParameter("Zielfeld");
function main()
var StartDate = issue.getNewFieldValue(fieldDueDate);
var StartDate = new Date().setTime(StartDate.getTime()+(CompValue*24*60*60*1000));
issue.setFieldValue(targetField, StartDate); // set field to due date
The red line is the one which causes the error.
The Trigger-Config has three fields:
  • "Startfeld" (the first datefield),
  • "Zielfeld" (the target datefield)
  • "Anzahl Tage", which holds the Number of days to compute with.
So how we get rid of this Javascript-Error? First we tried to catch an empty field by the trigger-rule with looking for a "Startfeld" != -unspecified-
but this doesnt work. So we tried to get this in the script by an if-statement in the main-function like:
if (fieldDueDate != null)
but this has no effect, this if-Statement is always false.
Other if-Statements were
if (!fieldDueDate)
or
if (!isNaN(fieldDueDate))
are always true, so we never get into the function. Can someone help me, please ? Thanks in advance...
kind regards, Jens
    Hi Jens,
    In situations which usually cause this error, it is because of a blank parameter. When the trigger attempts to pull a value from the parameters defined (in this case 'Startfield'), it finds nothing there. Is the trigger properly configured with all necessary parameters?
    JensN.1-VisitorAuthor
    i think it is properly configured. Its a pre-trigger and here is the rule:
    and
    |- Type = <Itemtype>
    |- Startfeld <> Startfeld [new Value]
    + or
    |- Startfeld <> - Unspecified -
    |- Startfeld [new Value] <> - Unspecified -
    So i want to trigger every time the value of "Startfeld" is changed and i want not to trigger if the field is empty. But this is my first problem: the "unspecified"-statement doesnt work, the trigger is always triggering. If this would work, we wouldnt have to handle this problem in the script.
    kind regards, Jens
    Ah I see. You can remove the "Startfeld <> - Unspecified -" part of the rule. This particular piece is checking the value of Startfield before the transaction and because it is looking for non-empty values, the trigger would fire even if it had a value.
    The "Startfield [New Value]" portion is all you need since the New Value element is checking the value at the end of the transaction. If the field started NULL but then was given a value, the trigger will not fire (exactly as expected).
    Hope that helps!
