changing the default settings
Is there any way to redirect the creation of IntegrityClient.rc file to create in another UNIX location instead of UNIX home directory, By default the file is creating in the user's home directory. We needs to setup the client so that the file IntegrityClient.rc can create in /var/tmp
    This is possible if you create a startup script for your Integrity Client.
    For your example on UNIX, you would want to set the MKS_IC_PROPERTIES and MKS_IC_INSTANCE_DIR environment properties to /var/tmp.
    MKS_IC_PROPERTIES=/var/tmp
    export MKS_IC_PROPERTIES
    MKS_IC_INSTANCE_DIR=/var/tmp
    export MKS_IC_INSTANCE_DIR
    I have included a sample batch script for Windows below:
    @ECHO OFF
    title "10.7 Client"
    :: Set the PATH variable to the Integrity Client's bin directory
    set PATH=C:\Program Files (x86)\Integrity\IntegrityClient10_7\bin;%PATH%
    :: Set the variable for this client's preferences file
    set MKS_IC_PROPERTIES=C:\Program Files (x86)\Integrity\IntegrityClient10_7\PersonalSettings\IntegrityClient.rc
    :: Set the variable for this client's viewsets, sandbox registry
    set MKS_IC_INSTANCE_DIR=C:\Program Files (x86)\Integrity\IntegrityClient10_7\PersonalSettings\
    :: Switch to this client's bin directory to ensure we run commands from this context
    cd C:\Program Files (x86)\Integrity\IntegrityClient10_7\bin
    :: Start the client process
    im gui
    @ECHO OFF
    title "10.7 Client"
    im gui
    sgovindan1-VisitorAuthor
    Excellent Joe, Kudos !!!!!
