Checkout Folder at certain Checkpoint
Hello everyone,
let's say I have the following PTC Project Structure:
A
|->SubfolderOfA
|-->SubSubfolderOfA
|-->AnotherSubSubfolderOfA
B
|->SubfolderOfB
Now "SubfolderOfA" has various Checkpoints, say v1.1, 1.2, 1.3, etc...
Now this is what I'd like to do, all of that <from the command line using si>:
> I'd like to checkout somewhere on my Filesystem (outside of any Sandbox) only "SubfolderOfA" (and all of it's child-Folders) and then switch between its various Checkpoints.
From what I could read in this forum, a build-sandbox could be a good starting point, like:
si createsandbox -P$MKS.pj --projectRevision=1.1
But, supposed the first step is right, how can i switch between the various Checkpoints of "SubfolderOfA"?
Thank you for your help!
Martino
    kthiererAnswer
    I got the same error
    then I checked with
        si sandboxes
    if this really is true.
    This then brought me to the idea to try
    si retargetsandbox --projectRevision=1.2 c:\absolute\path\to\project.pj
    For me this seems to work.
    BTW: You could also try %cd%\project.pj if your current directory is the sandbox.
         Jürgen
    mgrullo1-VisitorAuthor
    Hello, a little update from my side.
    I've executed the following commands:
    si createsandbox --projectRevision=1.1 .
    si retargetsandbox --projectRevision=1.2 .
    But the latter gives me the following error:
    Failed to retarget sandbox .: Retarget failed: The specified sandbox is not registered as a top level sandbox
    Same error with an additional argument:
    si retargetsandbox --projectRevision=1.2 project.pj
    Using the GUI I'm able to retarget the sandbox successfully: 'Sandbox'->'Retarget'
    So what am I doing wrong with the call to retargetsandbox?
    Thank you
    Martino
    kthierer12-AmethystAnswer
    then I checked with
        si sandboxes
         Jürgen
    This brought me to the idea how to generate a more compact view of
    project differences (members only, no subprojects)
    si retargetsandbox --projectRevision=1.6 %cd%\project.pj
    si print --recurse > sb_1_6.txt
    si retargetsandbox %cd%\project.pj
    si print --recurse > sb_CURRENT.txt
    si difffiles --gui sb_1_6.txt sb_CURRENT.txt
