CLI - Create a Test Suite and a Test Session
Hi there,
I am trying to create a Test Suite with Test Cases and later a Test Session within a batch script. For the Test Cases I am using "im createcontent" but I have no clue which commands to use for the Test Suite and Test Session. Is it possible to create such elements / documents with a batch script? If yes, how? 🙂
Hello @JosefK,
you need to keep the integrity document model in mind (see support document CS186280 ).
First you need to create your Test Suite (segment)
im createsegment --field='Project=/Project2/Release 1.0' --type='Test Document' --field='Category=Document'
Then you can add your content (node)
im createcontent --parentID=23 --insertLocation=first
You can then create your test session using
im createissue --type="Test Session" --field="Summary=Tests for..." --field="Project=/Projects/Release1" --field="Test Objective=Hardware Testing"
Dominik
Hello @JosefK,
Dominik
JosefK1-VisitorAuthor
Thanks a lot. Createsegemnt was the last piece in the puzzle for my problem 😉
